Reverse |
With a Reverse Link, every time a property's value is modified, this value is copied to the source, thus working conversely to a Simple Link. To use this resource, follow these procedures:
1.Open the object's properties window and select the Links tab.
2.Select the property to create a Link and click the Reverse Connection item.
Reverse Link
