Multiple |
In a Multiple Link, each Link row allows retrieving its value from a different source. The active source is selected according to the Link's main source value.
Each row contains an interval (the Min and Max properties) and the source for that interval (the Source property, which is a normal Link). To use this resource, follow these procedures:
1.Open the object's properties window and select the Links tab.
2.Select the property to create a Link and click the Multiple Connection item.
3.Define the Link's main source on the Source column.
Multiple Link
The available options for this Link are described on the next table.
Available options for a Multiple Link
Option |
Description |
Add |
Inserts a new row on the table |
Remove |
Removes the selected row from the table |
Min |
Specifies the minimum value on the source for a table row |
Max |
Specifies the maximum value on the source for a table row |
Source |
Specifies the source to be linked to the property when the value of the main source is between Min and Max limits |
Keep all active associations |
Keeps all table Links in Advise (active) mode. This option corresponds to the AdviseAll property |
