Analog |
An Analog Link allows users to establish a conversion scale between the source and the destination variable. By using these specified values, a linear scale is performed between property and source values.
Analog Link
The available options for this Link are described on the next table.
Available options for an Analog Link
Option |
Description |
Value on Source |
Determines maximum and minimum values reached on source |
Value on Property |
Determines maximum and minimum values reached on property |
To use this resource, follow these procedures:
1.Select the object for the Link.
2.Right-click this object and select the Properties option.
3.Click the Links tab and select the property to create the Link. E3 Studio indicates several types of Links.
4.In the Source option, select the Link and click to indicate the property to create a reference, or write down an expression in this option.
