Limitations of Demonstration Mode |
Without a product key, E3 can be executed in Demonstration (or Demo) mode, which is useful for software evaluation. In this case, the following limitations apply:
•Allows saving projects with up to 20 I/O Tags
•Does not allow working with servers in Hot-Standby mode
•Does not allow working with Remote Domains
•Only allows communicating with one Level 0 (zero) I/O Driver, without Tag limitations. Drivers with a level greater than 0 (zero) are not allowed
•Does not allow access to Domain configurations, available on the E3 Admin's Domain - Options contextual menu on Windows Notification Area
•Only the first image of each category in the Symbols Gallery is available
•Only allows opening one E3 Viewer or WebViewer
•The maximum execution time of a Domain is two hours
•Only allows recording up to 20 I/O Tags on a Storage object
•Allows access as an OPC Server
•Allows executing a playback of the last six hours of data, relative to the current server time, with an unlimited number of Tags, and all playback resources enabled
•Does not allow using E3 Admin's Export Users tool
•Does not allow using E3 Studio's Import and Export tool
