Block Diagram |
E3's internal architecture is completely scalable, with each main task executed by a separate service. The following diagram shows an overview of its main blocks.
E3's block diagram
Briefly, an E3 Server is responsible for creating an executing a process (E3Run) that effectively executes the application. Within E3Run there are other servers that expose services used by other modules.
