Value Sets |
The third tab on Formula's view is called Values. Value Sets are values transferred to Tags, that is, to Units.
Values tab
Available options for Values tab
Option |
Description |
Name |
Determines Template's name |
Determines field values for Value Sets |
This view's toolbar contains the Add option, to create a new Value Set, the Remove option, to delete the selected Value Set, and the Rename option, to rename the selected Value Set.
