Units
Units
The second tab on Formula's view is called Units. Units define Tags linked to Formula Templates. Users can create several Units, that is, several Tag groups that can receive Formula values.
Units tab
Units tab
The available options on this tab are displayed on the next table.
Available options for Units tab
Option
Description
Name
Specifies Template's name
Unit
Specifies a Tag to link to this Unit
This view's toolbar contains the Add Add option, to create a new Unit, the Remove Remove option, to delete the selected Unit, and the Rename Rename option, to rename the selected Unit. For each new Unit, the window on the next figure is displayed to define a name.
Adding a Unit
Adding a Unit
