Settings |
When creating a Formula, a window for configuring a Database and a table to use is displayed. Without it, users cannot create Units and Value Sets.
Database and table configuration window
Available options for Database Configuration window
Option |
Description |
Database |
Specifies the Database Server that manages data configured in this Formula. This field is equivalent to the Formula's DBServer property |
Table |
Specifies the name of the table where Formula data is stored. This field is equivalent to the Formula's TableName property |
Maximum size for Unit fields |
Specifies the maximum size for Unit fields on the Database table. Default value of this field is 200. This field is equivalent to the Formula's DataSourceSize property |
Maximum size for Value fields |
Specifies the maximum size for Value fields on the Database table. Default value of this field is 200. This field is equivalent to the Formula's ValueSize property |
If users want to configure these items later, or even reconfigure them, select the Configure Database option on Formula's contextual menu.
Configuring a Database
