E3 Viewer |
Possible cause
There is a firewall blocking access to this Server.
Solution
Users must unblock all ports used by E3. The procedure to unblock a port on Windows Firewall is described next.
NOTE |
The default port used by E3 is 6515, but this behavior can be changed according to topic E3 Viewer and WebViewer - E3 Viewer Execution - Via Start Menu. |
1.Go to the Start - Control Panel menu.
2.Click Windows Firewall.
3.Click Advanced Settings.
4.Right-click the Outbound Rules item and select the New Rule option.
5.On the Rule Type window, select the Port item and click Next.
6.On the Protocol and Ports window, select the TCP option and, on Specific remote ports item, type the number of a port to unblock and click Next.
7.On the Action window, select the Allow the connection item and click Next.
8.On the Profile window, leave the Domain, Private, and Public options selected and click Next.
9.On the Name window, type a name and a description (optional) for this port and click Finish to save these changes and close this window.
Possible causes
•An E3 Viewer is not installed in the remote computer
•There is a firewall blocking access to this server
Solution
Users can install an E3 Viewer on the remote computer or else copy E3 Viewer's installation file to Server's folder c:\inetpub\wwwroot. Thus, every time there is an attempt to open an E3 Viewer using Internet Explorer on a remote computer where an E3 Viewer is not installed, the installation process starts immediately.
