Event List
Event List
An Event List displays a chronological sequence of playback events, which allows an event-by-event browsing. A playback event can be:
A change on a Tag value
A change on an alarm status
Event List
Event List
Columns on this window are described on the next table.
Columns on the Event List
Column
Description
Date/time
Displays this event's date and time, as stored on the database
Tag Path
Displays the Tag's or alarm source's path that generated this event, or the Bookmark's name
Event
If this event is a change on a Tag value, displays this new value. If quality is not Good (192), it is displayed before the value (for example, "Bad(20); 45.433"). If this event is a change on an alarm status, displays the sub-condition's name (HI, HIHI, LO, LOLO, etc.) and alarm's description. If this alarm is (or was) acknowledged, displays an "ACK" text at the beginning, with the operator's name inside parentheses. If it is a Bookmark, this field displays its associated comment
The Event List's toolbar contains the options described on the next table.
Options on the Event List's toolbar
Option
Action
Previous Event Previous Event
Places the playback clock at an event previous to the selected one on this list, skipping events with a timestamp equal to the current timestamp
Next Event Next Event
Places the playback clock at the next event with a timestamp greater than the current timestamp
Filter Events Filter Events
Turns an event filter on or off. When turning a filter on, only events from the current selected Tag or alarm source are displayed on the event list. Bookmarks are always displayed, even if a filter is on
Filter Bookmarks Filter Bookmarks
Displays only Bookmarks that were created
When right-clicking an event, a contextual menu is displayed with the options described on the next table.
Options for an event's contextual menu
Option
Description
Show or Remove chart on Timeline
Adds or removes a visual representation of this Tag on the Timeline window
Show only events from this tag or Show all events
Filters events on the Event list to display only the selected Tag. Selecting this option again displays all events
