Connections Tab
Connections Tab
The Connections tab allows configuring one or more connections to local or remote Alarm Servers.
Connections tab
Connections tab
Available options on the Connections tab
Option
Description
Add Connection Add Connection
Adds a new Connection to an E3Alarm. This option corresponds to the Add method of the Collection of Connections
Remove Connection Remove Connection
Removes the selected Connection. This option corresponds to the Remove method of the Collection of Connections. NOTE: The Connection created automatically with an E3Alarm cannot be removed
Connection Name
Name of this Connection. Press the F2 key to edit this name. This option corresponds to Connection's ConnectionName property on the Collection of Connections
Domain
Friendly name to identify the Domain of the selected Alarm Server. This option corresponds to Connection's DomainName property on the Collection of Connections
Alarm Server
Name of an Alarm Server, which can be on a local Domain as well as on a remote Domain. This option corresponds to Connection's AlarmServer property on the Collection of Connections. Click Select Alarm Server to select an Alarm Server using AppBrowser
Connection filter
Name of a Filter that contains settings for alarm filters, defined on the Filters tab. This option corresponds to Connection's FilterConnection property on the Collection of Connections
Users can access a remote Alarm Server by simply filling Connection's AlarmServer property of E3Alarm's Collection of Connections with data for remote Domain and Alarm Server, in the format DOMAIN:SERVER, where SERVER is the name of the remote Alarm Server and DOMAIN is the name of a Remote Domain that contains it. To configure a Remote Domain, please check topic Remote Domain on the Domains chapter.
