Substatus Field
Substatus Field
This field's layout depends on the Quality field.
Substatus for BAD Quality
SubStatus
Description
Limit
No Limit
Low
High
Constant
Non-specific
This value is bad, but no specific reason is known
0
1
2
3
Configuration Error
There is some specific configuration problem in the server. For example, this specific item could be deleted
4
5
6
7
Not Connected
Input must be logically connected to something, but it is not. This quality may reflect that no value is available at this time, because this value could not be provided by its data source
8
9
10
11
Device Failure
A device failure was detected
12
13
14
15
Sensor Failure
A sensor failure was detected (the Limit field may provide additional information)
16
17
18
19
Last Known Value
Communication failed. However, the last known value is available. Notice that this value's age may be determined by the Timestamp property
20
21
22
23
Communication Failure
Communication failed. There is no last known value available
24
25
26
27
Out of Service
Block is off scan, or locked
28
29
30
31
N/A
Not used
32 - 63
Substatus for UNCERTAIN quality
SubStatus
Description
Limit
No Limit
Low
High
Constant
Non-specific
There is no specific reason
64
065
066
067
Last Usable Value
A device providing this value stopped doing so. The returned value must be considered as old. Notice that this differs from a Bad value with Substatus 5 (last known value). That status is associated specifically with a detectable communication error on a retrieved value. This error is associated with a failure of some external source that would insert something into this value within an acceptable period of time. Notice that this value's age can be determined by the Timestamp property
68
069
070
071
N/A
Not used
72 - 79
Sensor Not Accurate
Either this value is stuck at one of sensor's limits (in which case the Limit field must be set to 1 or 2) or this sensor is otherwise known to be out of calibration via some internal diagnosis (in which case the Limit field must be zero)
80
81
82
83
Engineering Unit Exceeded
The returned value is outside the limits defined for this parameter. Notice that in this case the Limits field indicates which limit was exceeded, but does not necessarily imply that this value cannot move outside the specified range
84
85
86
87
Sub-Normal
This value is derived from multiple sources and there is a number smaller than required of good sources
88
89
90
91
N/A
Not used
92 - 127
NOTE
Servers that do not support Substatus must return 0 (zero).
Substatus for GOOD Quality
SubStatus
Description
Limit
No Limit
Low
High
Constant
Non-specific
This value is good. There are no special conditions
192
193
194
195
N/A
Not used
196 - 215
Local Override
Typically indicates that an input was disconnected and a manually-entered value was forced
216
217
218
219
N/A
Not used
220 - 255
NOTE
Servers that do not support Substatus for good quality must return 0 (zero).
