Limit Field |
The Limit field is valid regardless of Quality and Substatus fields. In some cases, such as a failure on a sensor, it may provide diagnosis information.
Limit Field
Specification |
Description |
Not Limited |
This value is free to move up or down |
Low Limit |
This value is limited at some lower limit |
High Limit |
This value is limited at some higher limit |
Constant |
This value is a constant and cannot move up or down |
NOTE |
Servers that do not support the Limit field must return 0 (zero). |
