Servers Tab |
Users can add, remove, or edit servers of a Domain. Use the list on the left to select one or more servers to change. This list also indicates whether a server is enabled , in Maintenance mode, or disabled . To open this item, right-click the E3 Admin icon on Windows Notification Area, select the Domain - Options option, and then click the Servers tab. The window on the next figure is then displayed.
Servers tab
Available options on the Servers tab
Option |
Description |
Name |
List with all servers in an application |
Add and Remove |
By using this option, users can add or remove servers. To add a network server, click Add and specify the Server Name and Network Address fields. To add a local server, specify the Use the following local folder item. To remove a project, select it on the list and click Remove |
Server name |
Determines a server's name. This is a user-defined name |
Network address |
Inform this server's name on the network. This must be a machine's name with or without double backslashes at the beginning, such as \\server or server |
Root folder for Domain files |
Indicates a folder where Domain files (.prj, .lib, etc.) from the selected server are located. The Leave it blank (Use .DOM file's folder) option is the default and indicates that files are on the same folder of the Domain file (.dom). If users select the Use the following local folder option, the path typed in that specific field must only contain a folder, without Domain's file name or extension (.dom) |
Maintenance mode (disabled) |
This option allows disabling a server, thus not using it when executing the Domain. When this option is enabled, the icon indicates this server is not used. Otherwise, the icon indicates this server can be used |
