Projects Tab |
Users can add, remove, or edit projects (.prj files) of a Domain. To open this item, right-click the E3 Admin icon on Windows Notification Area, select Domain - Options, and then click the Projects tab. The window on the next figure is then displayed.
Projects tab
Available options on the Projects tab
Option |
Description |
Name |
This option lists all names of projects in an application |
Add and Remove |
By using these options, users can remove or add projects in an application. To add a project, click Add and then fill in the Project Name field. To remove a project, select it and then click Remove. The PRJ file is not deleted from disk, only from Domain's project list |
Project Name |
Type the name of a project file, which must be a path relative to Domain's directory, that is, the directory containing the .dom file, such as Screens.prj or Hydro\Station1.prj |
Maintenance mode (disabled) |
This option allows disabling project's execution, thus avoiding errors when a Domain is executed. When this option is enabled, the icon indicates this project is not used. Projects displaying an icon are enabled and are executed |
