Manual Server Switch |
Generated whenever a Domain's backup server activation is forced, via E3 Server's Server - Activate menu, where:
•%USER% contains the user's login name who activated the backup server (or "Anonymous" if no authentication was requested when that server was activated)
•%SESSION% contains "E3 Server" (menu on Windows Notification Area)
•%MACHINE% contains the name of the computer where the command to activate the backup server was generated
