Timer Tag |
A Timer Tag is an object used for counting time and scheduling activities that establishes a time schedule, with repetitions, to execute certain actions. To use this object, follow these procedures:
1.Right-click a Data Server and select the Insert - Panel - Timer Tag option.
Inserting a Timer Tag
The system opens up a window asking the number of Tags to create in the Server, as well as their names. This name is auto-incremented; if this option remains blank, Tags are created with a default name.
Adding Timer Tags
Some Timer Tag properties can be configured using the Properties List, without creating scripts for this. To configure any property, just locate it on the Properties List and perform the necessary adjustments.
