Demo Tag |
A Demo Tag is an object that generates values according to a wave shape, and it is used to simulate values. It allows generating defined waves or random values. To use this resource, follow these procedures:
1.Right-click a Data Server and select the Insert - Panel - Demo Tag option.
Inserting a Demo Tag
The system opens up a window asking the number of Tags to create in the Server, as well as their names. This name is auto-incremented; if this option remains blank, Tags are created with a default name.
Adding Demo Tags
Some Demo Tag properties can be configured using the Properties List, without creating scripts for this. To configure any property, just locate it on the Properties List and perform the necessary adjustments.
