Digital Alarm |
Allows monitoring a digital variable by specifying whether this alarm is rising, in -1 (minus one) or True, or falling, in 0 (zero) or False.
Digital tab
Available options for the Digital tab
Option |
Description |
Enable |
Enables a digital alarm |
Determines a Boolean value for this alarm, that is, True or False |
Message text |
Allows specifying a text displayed to users when this alarm is in an active condition |
Severity |
Specifies an alarm level's severity. Available options are Critical, High, Medium, or Low |
Need Ack |
Enables or disables alarm acknowledgment |
Delay (ms) |
Specifies a delay time, in milliseconds. When this value is equal to 0 (zero, default), no delay is applied |
Return message |
Allows specifying a text displayed to users when this alarm is not in an active condition |
Allow shelving |
Enables or disables shelving this alarm |
Maximum shelving time |
Maximum time, in minutes, this alarm can remain shelved. Default value of this options is 60 (one hour) |
Maximum shelve count |
Maximum number of times this alarm can be shelved. Default value of this option is 0 (zero), that is, no limit |
