IIS Configuration with E3 Server on the Same Machine
Together with E3 installation, the files e3web.asp, e3web2.asp, docwrite.asp, docwrite2.asp, and e3downloader.cab are already sent (located on the directory where E3 was installed, on the web folder. These files must be placed on the directory c:\inetpub\wwwroot, which is created during IIS installation. Apart from these files, users must also place WebViewer's installer package (e3webviewer-x86-enu.exe). This installer is used when a client station accesses a server for the first time, if E3 was not previously installed on it. This file can be obtained on Elipse Software's website.
NOTE
The file e3webviewer-x86-enu.exe must match the executing E3 Server's version and build. Users must update all files on IIS directory if they update E3 Server's version.
After copying these files to folder c:\inetpub\wwwroot, users can start configuring IIS.
