Full Install
Full Install
1.Plug the protection device (Hardkey-type) in the computer's USB port. E3 validates licenses based on this device.
2.Execute the file e3full-x86-enu.exe or e3full-x64-enu.exe and follow the on-screen instructions.
3.An Installation Complete message appears when installation is finished. A program group named E3 is then created on Windows Start menu.
NOTES
For a time-limited protection device installation, E3 Server shows, on Windows Notification Area, messages warning how much time remains (in days, hours, and finally minutes) until product key expires.
To install E3 using a Softkey-type protection device, please contact Elipse Software.
E3's installer supports the /NOACP command prompt option, which ignores the installation of ActiveX Control Pad (MS Forms). This option must only be used if application screens do not use MS Forms components.
Some applications, such as MS Office, install ActiveX Control Pad during their installation process.
