Frequently Asked Questions
During installation, a message "There are E3 modules running on this machine. Please stop them and restart installation" is displayed
possible reason
Another E3 version is installed and opened while trying to install a new version.
SOLUTION
Close the older version first, and then continue the installation by clicking Retry.
During installation, a message "Files in use. Files that need to be updated are in use" is displayed
possible reason
An Elipse SCADA version is installed and opened while trying to install E3.
SOLUTION
Close Elipse SCADA and continue E3 installation by clicking Retry.
After installation, a message "E3 Studio license not found in this server. Do you want to run in demo mode?" is displayed when I try to execute E3 Studio
possible reason
There are two possible reasons:
a)Protection device or detection drivers are not correctly installed.
b)USB port setup is not correct or this port is damaged.
SOLUTION
For each reason, try the following:
a)Execute HaspDinst.exe application with -I option. This can be performed via Run option on Windows Start menu. The command prompt is:
C:\Program Files\Elipse Software\E3\HASP\haspdinst.exe -I
b)Test USB port with another known device, such as a printer. Users can also check on computer settings whether this USB port is correctly configured.
For more information about E3's Demo mode limitations, please check topic Limitations of Demonstration Mode on E3 User's Manual.
I moved the application to another computer and now it does not display images anymore
possible reason
Path to picture files is incorrect.
SOLUTION
Users must create the same directory structure (the same path) as the original computer.
