Open Screen Pick
Open Screen Pick
Let's implement navigation among application Screens. InitialScreen must open Frame1 and each Command Button on MenuScreen must open its respective Screen on Central_Area Frame or in full screen.
1.Configure InitialScreen to be the first Screen of this application. This can be accomplished in the following ways:
•By adjusting that Screen to _top Splitter and then selecting the Set as initial Splitter's Screen option
•By selecting InitialScreen in the Initial Screen or Frame item of Viewer's Properties Window
NOTE
The initial Screen adjustment was covered on topic Initial Screen or Frame of the Application of chapter Structure of Screens and Frames.
2.On InitialScreen, select the "Login" Text and click the Scripts tab.
3.On Click event, create a new Open Screen-type Pick.
4.In the Open Screen field, select the Frame1 item.
5.Leave the In Frame option blank.
Open Screen Pick
Open Screen Pick
