Toggle Value
Toggle Value
Allows toggling the value of a Tag. If the value of a Tag is equal to Value1, then the Tag receives Value2. If the value of a Tag is equal to Value2, then the Tag receives Value1. If the value of a Tag is different from either Value1 or Value2, then the Tag receives Value1.
Toggle Value Pick
Toggle Value Pick
