Microsoft Forms Controls
Microsoft Forms objects are software components based on Microsoft COM (Component Object Model) technology. Elipse E3 installs and uses Microsoft Forms controls. They can be inserted on application Screens to handle several tasks. The next table contains a description of all these objects.
Object
Description
Check Box Check Box
Gives users a choice between two values, such as Yes and No, True and False, or On and Off
Option Button Option Button
Shows whether an individual item of a group is selected
Command Button Command Button
Executes a specific action when pressing it
Label Label
Shows a descriptive text, such as titles, captions, etc.
List Box List Box
Displays a list of values
Scroll Bar Scroll Bar
Returns or defines the value of a property from another object, according to its scroll box position
Spin Button Spin Button
Increases or decreases a value
Text Box Text Box
Displays user-entered information on a Screen
Toggle Button Toggle Button
Similar to a Command Button, except that it needs a second user command to return to its normal status
Combo Box Combo Box
Combines features from a List Box and a Text Editor. Users can type a new value or select an existing value
NOTE
Other third-party ActiveX objects can also be used in Elipse E3, if they are properly registered. They can be added by using the Tools - Manage ActiveX menu.
