Viewer
Viewer
A Viewer object configures the way Elipse E3 Viewer is displayed.
Elipse E3 Viewer can be launched from any point on a network that has access to an Elipse E3 Viewer. It is not necessary to copy an application to every computer where Elipse E3 Viewers are executed, because Screens and bitmaps are retrieved from a server when needed, at run time.
NOTE
A Domain can have only one Viewer object.
On the Viewer tab of Properties Window, Viewer's visual settings are configured.
E3 Viewer tab
E3 Viewer tab
By using the Settings tab, users can configure Viewer's window, title, and resolution.
Settings tab
Settings tab
On the Communication Errors tab, users can define a pattern so that Displays and SetPoints of the whole application indicate communication errors.
NOTE
Users can also insert Tags on a Viewer.
