Expression
Expression
1.To modify liquid's color, create the Link shown on the next figure on the Rectangle object of Tank 1.
Link with an expression
2.Select on AppBrowser the VBScript's RGB method.
3.Replace the words "Red", "Green", and "Blue" by the Red, Green, and Blue Tags, respectively.
TIP
Work with the Copy (CTRL + C) and Paste (CTRL + V) commands. To edit a previously created Link, use the F2 key.
4.Repeat the previous steps for the second tank.
