Retentive Property |
The Retentive property determines whether a value must be stored in case of switching the active server. Thus, when the server in Standby mode is executed, the value is the same as the server in Hot mode when it was stopped. If this property is set to False, the property is set to its initial value whenever the Domain is executed or the active server switches.
