Creating and Accessing Variables
On Query's configuration window, users can add filters directly in the fields. These filters can be built using script-defined variables via Query's SetVariableValue method. The way to declare variables depends on the data type they represent, as shown next:
•Numbers: <%Variable_Name%>
•Strings: '<%Variable_Name%>'
•Date and time: #<%Variable_Name%>#
