Alarm Server
Alarm Server
1.Open Alarm Server's Properties Window and, on the Configuration tab, enable the Store alarms on a database option.
Configuration tab of an Alarm Server
2.In the Database Server option, select the Database item.
3.Enable the Discard data from the main table option.
Keep data from the last 3 (three) months
Check must occur at every 1 (one) month
4.Click Fields and select the InTime field and any other field needed.
5.Finally, click Create table. A successful message must be displayed, as shown on the next figure.
Success message
Success message
