Tanks
Tanks
This application represents a plant that uses as its raw materials red, green, and blue inks, producing other inks as a combination of these three ones.
1.On the Data folder, create a Data Folder named "Tank1" and insert three Internal Tags, "Red", "Green", and "Blue".
Tank1 Folder
Tank1 Folder
2.Configure the initial value of those Tags to Integer.
Selecting a data type
3.Create a copy of Folder Tank1 to create Folder "Tank2".
Data Folders
Data Folders
NOTE
Users can use the shortcut keys CTRL + C and CTRL + V to copy Tank1 Folder and then paste it on the Data Folder.
