Simulation of Values
Sometimes users need values that simulate movements. Usually these values are real and come from I/O Tags, but all exercises of this Tutorial use Demo-type Tags.
1.On the Data folder, insert a Demo Tag. To do so, locate the Server objects item in Organizer and inside it the Data Objects item. Right-click the Data folder and then select the Insert - Panel - Demo Tag item.
Insert a Demo Tag
Insert a Demo Tag
2.Configure this Demo Tag according to the first row on the next table and insert three more Demo Tags, configuring them according to the other rows on the table.
Properties of Demo Tags
Name
DocString
Minimum
Maximum
Period
Scan
Type
Level1
Level of Tank 1
0
100
20000
200
6 - RampUpDown
Level2
Level of Tank 2
0
100
30000
200
6 - RampUpDown
Temp1
Temperature of Tank 1
20
80
20000
500
1 - Sine
Temp2
Temperature of Tank 2
20
80
10000
1000
0 - Random
Demo Tags created
Demo Tags created
