Number of PLCs |
Simulator creates PLCs in all ports consecutive to the value configured in the Initial Port field. For example, when configuring three PLCs starting at port 502, the first PLC is available on port 502, the second one on port 503, and the third one on port 504.
PLCs Quantity
NOTE |
PLCs created consecutively to the value configured in the Initial Port field only use available ports. In the previous example, if port 503 is in use by another application, PLCs are created on ports 502, 504, and 505. |
