Elipse Modbus Simulator
Elipse Modbus Simulator is a generator of random values for applications compatible with Modbus RTU and Modbus TCP protocols. In addition, it also allows receiving writing messages performed by these applications. This program can be downloaded at Elipse Software's website. When Simulator starts, its working area opens, as shown on the next figure.
Elipse Modbus Simulator's main window
The available options on this main window are described on the next table.
Available options on Elipse Modbus Simulator's main window
Option
Description
PLCs Quantity
Number of PLCs to simulate. NOTE: In Demo version, this field is limited to 10 PLCs
Initial Port
Base port used for communication
Random Values
Enables or disables generation of random values
Interval (ms)
Variation range of values, in milliseconds
Connection
Type of connection to simulate. Currently, the only available option is TCP/IP
Protocol
Protocol to simulate. Available options are Modbus RTU or Modbus TCP
COILS
Number of Coils to simulate per PLC. Maximum limit is 255
REGISTERS
Number of Registers to simulate per PLC. Maximum limit is 255
After selecting the amount of PLCs and an initial port, start simulation by clicking Start.
