Drivers and I/O Server
Fixed the Driver Manager window of E3 Admin to always keep updated and sorted the list of objects executing in each shared Driver.
Improved the performance of adding or removing I/O Tags during the execution of a Driver, in situations in which this Driver is continuously performing readings or writings. This bug occurred since v0.1.1.
Improved sending data from I/O Server to E3Run, to avoid that a Driver that generates a lot of data lock the sending of data from the other Drivers in the same I/O Server.
