TrendAnalysis |
•Fixed a memory leak that could occur when closing an instance of TrendAnalysis. This bug occurred since v6.0.187.
•TrendAnalysis now correctly indicates if there is an error when loading a file in XML format. This bug occurred since v6.0.197.
•The option to export to CSV format now works correctly. This bug occurred since v6.0.197.
•Fixed a GPF (General Protection Failure) that could occur when removing pens via keyboard. This bug occurred since v6.0.197.
•Fixed a possible failure when browsing Tags of a connection. This bug occurred since v6.0.197.
•The drawing of the column with the name of a Pen does not overlap anymore the other columns of the Penas area on the Displays tab. This bug occurred since v6.0.197.
