Scripts
Scripts
Fixed the behavior of Multiple Links created at run time. This bug occurred since v4.6.98.
The prefix "s" was removed from the Index parameter of methods of E3Alarm and Alarm Filter objects. This bug occurred since v4.7.63.
Fixed the access to the Item method of server objects, which could be blocked on read-only Elipse E3 Viewers or Remote Domains. This bug occurred since v4.0.62.
Fixed a possible failure of a Domain when using the Save command in Demo mode. This bug occurred since v1.17.1.
Fixed the usage of VARIANT values with VT_INT and VT_UINT data types in properties, such as a Tag's Value property. This bug occurred since v1.20.86.
Fixed the behaviour of the Application.GetObject method to always check the path passed on the ObjectPath parameter to the end, not accepting that it finishes in a property that is not an object. This bug occurred since v1.18.155.
Blocked the creation of definitions of ElipseX objects (XControls, XObjects, and XFolders) in projects or folders using Studio's CreateFile method. This bug occurred since v4.0.102.
