Studio
Studio
•Improvements on Elipse E3 Studio interface:
•Implemented a middle-click to close the tab under mouse pointer
•Implemented an option to display a button to close the active tab on the tab itself, or on the right side of all tabs. This option can be configured in the Options window, on Tools menu
•Other improvements in Options window of the Tools menu:
•Changed the name of Studio tab to General, and also changed its position to be the first one
•Changed the name of Editor tab to Scripts Editor
•Adjusted the size of Studio tab to conform to the standard
•Created shortcuts to open Log Viewer and E3 Tweak from inside Elipse E3 Studio, as well as shortcuts to open Log Viewer, Elipse E3 Studio, Elipse E3 Viewer, and E3 Tweak from E3 Admin.
Shortcuts on Elipse E3 Studio and on E3 Admin
•Created methods CreateFile, CreateFolder, and CreatePRJ in Studio's Application object.
•Created the method RenameFolder to rename a Folder via scripts executing in Studio.
•Removed an unused space on the left side of cells on the first column of all tables in Elipse E3 Studio that are not hierarchical, such as the Links tab.
•Implemented a window for scripts execution errors in Elipse E3 Studio, the same one appearing in Elipse E3 Viewer.
•Implemented a cache of images or Metafiles in Elipse E3 Studio. Thus, if the same image is used several times on the same Screen, or on different Screens, it is loaded on memory only once.
•Gallery does not display error messages relative to Screen or XControl loading anymore.
•The Screen Editor now always adjusts object coordinates to the nearest pixel (a Snap to Pixel effect). Also added the shortcut key CTRL + SPACEBAR, which moves the selected objects to the nearest pixel.
•Gallery thumbnails are now drawn using the High Quality mode (GDI+).
Gallery
Gallery
