Viewer
Viewer
•Fixed a script error message occurring when a Elipse E3 Viewer script tried to access a non-existing property or method in a Server object. The script error was displayed empty, instead of indicating "The object does not support this method or property". This bug occurred since v2.0.118.
•Fixed the behavior of the Elipse E3 Viewer's Login window, which did not stop login retries in case the window was canceled. This bug occurred since v2.0.118.
•Fixed a problem when resizing modal windows, when the lower or right corner was displayed on monitor's negative coordinates (or monitors). This bug occurred since v1.18.155.
•Fixed a problem when handling keys in Elipse E3 Viewer's modal screens, which lead KeyDown and KeyUp Screen scripts to be executed twice or more on every pressed key. This bug occurred since v2.0.90.
