Studio
Studio
The Domain Checker now performs a name consistency for Database Servers and the table of the Alarm Server object. This bug occurred since v1.18.147.
Added support for Undo operations when changes are performed through the Replace tool. This bug occurred since v1.20.382.
Corrected a problem with searching or replacing properties of type Color, where a value inside the color were found and replaced, which would change the final color of the property. For that, the behavior of the search and replace tool was modified to identify the data type of the search: String, Date, Color, Boolean, or Number. This bug occurred since v1.20.382.
Corrected a message of insufficient memory displayed in Elipse E3 Studio when Search or Replace is performed in objects which cannot be loaded. This bug occurred since v1.20.263.
Corrected a problem in Elipse E3 Studio when replacing values in fields already deleted, which may lead to a GPF. This bug occurred since v1.21.80.
Fixed a problem which caused Elipse E3 Studio to unexpectedly quit when pressing ESC in the Filter Class Configuration window of Importing and Exporting objects to CSV (Export - Advanced - Filters - Change). This bug occurred since v2.5.63.
Corrected a memory leak in Pick objects. This bug occurred since v1.20.22.
Corrected a problem when mirroring Arc objects when they are already rotated. The drawing of the Arc rotated and mirrored now is correct. This bug occurred since v1.18.147.
Corrected a GPF in Elipse E3 Studio when displaying the Property List or the Link window and the name of an ElipseX property is a special character, such as a Greek letter). This bug occurred since v1.18.147.
Now Elipse E3 Studio asks users if they want to save an unsaved application when Windows is restarted or shut down, or when users log off. This bug occurred since v1.18.147.
Corrected a GPF which occurred in Elipse E3 Studio when trying to convert a very complex metafile (WMF or EMF file) to a symbol. The conversion process was also improved, which could take seconds, now is nearly instantaneous. This bug occurred since v1.18.147.
Corrected a problem which occurred in windows which allowed moving Splitters. The cursor icon remained the default, while it was supposed to change to horizontal and vertical arrows. This bug occurred since v3.1.1.
Fixed a GPF (stack overflow) which occurred in Elipse E3 Studio when a large number of objects, such as 5000, of a Screen were selected at the same time. This bug occurred since v1.18.147.
The file msstkprp.dll now is installed and registered in the System32 Windows directory. The Font and Color tabs of E3Alarm, E3Chart, and E3Browser objects rely on this file. This bug occurred since v1.18.147.
Corrected a problem when double-clicking values of type Enum in the Property List. In this case, double-clicking was not changing the following value if the numbers were not continuous. This bug occurred since v1.18.147.
Corrected the behavior of auto-incrementing names of Elipse E3 Studio spreadsheets in several locations where names are not supposed to differentiate upper from lower case. This bug occurred since v1.18.147.
Fixed a problem in Elipse E3's Screen Editor in point editing of Polyline or PolyBezier objects. The operation of creating points was not being undone. This bug occurred since v1.18.147.
