E3Chart
E3Chart
Fixed a bug in E3Chart's legend, which displayed the message ":256" on Pen's status, even when it is properly connected. This bug occurred since v1.20.385.
Fixed a bug in E3Chart Pens' draw style: when not solid (for example, dotted), and sized 1 (one) or higher, it used to display a continuous drawing.
Fixed E3Chart's Dot Search mode, which did not work if data on X axis was not sorted out in ascending order.
Fixed E3Chart's Pens and Axes collections' behavior, which allowed the creation of objects with the same name. This bug occurred since v1.21.96.
When using a real time scale, now there is a 2-pixel margin on E3Chart that keeps Pen's current data from hiding behind the Axis line. This bug occurred since v1.21.96.
