Domain, E3 Server, and Hot-Standby
•Fixed a potential E3 Server's glitch when an I/O Server is unexpectedly terminated. This bug occurred since v3.0.359.
•Fixed retentive Tag's implementation, which handled Tag's name as case-sensitive and caused a Tag renamed from "tag" to "TAG" to lose its retentive value. This bug occurred since v1.21.96.
•Fixed a bug that occurred if an object was attributed to a retentive Internal Tag's value. The next time a Domain started, or when there was a switchover, all retentive Internal Tags remained in error. Now a retentive Internal Tag only retains object's value that had been attributed to it. This bug occurred since v1.21.96.
•Fixed a memory leak in E3 Server, only when in Hot-Standby, whenever an object was attributed to a retentive Tag. This bug ended up causing an Out of Memory error after a few hours. This bug occurred since v1.21.96.
