Via Elipse E3
Via Elipse E3
An Elipse E3 Viewer can be executed using the Default toolbar, using the following options:
Saves and Runs the Domain Saves and Runs the Domain: Saves all settings of projects and libraries, executes a Domain, and then executes an Elipse E3 Viewer
Runs or Stops Domain Run or Stops Domain: Starts or stops the execution of the current Domain
Refresh Domain Refresh Domain: Updates the current Domain
Runs or Stops Elipse E3 Viewer Runs or Stops Elipse E3 Viewer: Executes or stops the execution of the current Elipse E3 Viewer
When an Elipse E3 Viewer is executed, the application shows the window on the next figure, indicating a connection status.
Elipse E3 Viewer connection status
Whenever losing a server connection, Elipse E3 then tries to reconnect automatically, according to server's configurations. To determine which server performs a connection in case of an Elipse E3 Viewer failure, users must configure the Servers option, configured via E3 Admin, as explained in chapter Domains.
