Viewer Folder |
A Viewer Folder defines groups inside Viewer objects to organize Viewer Tags (Counter, Demo, Internal, and Timer) and Queries. If needed, new Folders can be inserted into other Folders. To use this feature, follow this procedure:
1.Right-click the View - Viewer and Frames - Viewer item and select the Insert - Panel - Viewer Folder option.
Inserting a Viewer Folder
NOTE |
An application that contains Viewer Folders cannot be opened on versions of Elipse E3 earlier than 3.1. |
