Version Report |
The Version Report tool enables viewing versions and comments of open projects and libraries, whether they belong to a Domain or not. To access this tool, click on the Default toolbar to display the window on the next figure.
Version Report
Available options for Version Report dialog box
Option |
Description |
Project/Library |
Name of an open project or library in a Domain |
Version |
Indicates a project or library version. This version is generated internally by Elipse E3 and it is incremented every time a project is saved, either manually or automatically. In case of protected projects and libraries, if this version cannot be saved, it cannot be incremented either. However, if users have permission to open and change a project or library, this version is incremented normally |
Comment |
Shows a project-related comment. This comment can be edited via DocString property. In case of libraries, this field remains blank |
NOTE |
These fields are strictly for viewing, therefore their edition is not allowed. |
