Properties List
Properties List
Properties List is a window for configuring properties of the selected object.
The Properties List's title always displays the name of the currently selected object. For this window to be visible in the project, users must select the Properties List Mostrar ou ocultar a Lista de Propriedades option on Visualize menu. The next figure shows a Properties List of an I/O Block Element object with its properties sorted alphabetically.
Properties List sorted alphabetically
The Properties List of the next figure displays the previous object with its properties sorted by category.
Properties List sorted by category
NOTE
When selecting multiple objects, the Properties List displays only properties common to the selected objects, with their values corresponding to the last selected object. The same criteria is used if the Properties List is sorted by category, that is, the displayed categories correspond to the last selected object.
The Properties List's footer displays a quick description of the selected property. The available options on this window are described on the next table.
Available options on Properties List
Option
Description
Categorized Categorized
Displays all properties of the selected object organized by category
Alphabetic Alphabetic
Displays all properties of the selected object organized alphabetically
Find Find
Allows filtering the list by the property's name or partial name
Users can configure a value to a property by typing it directly in its respective Value column. On the right side of a property's name there is an icon that indicates its status. The icon Default value indicates that property's value is the default, that is, its value was not modified by the user, and the icon Overriden value indicates that property's value was modified by the user. In this case, the modified value appears in bold. In addition, clicking this icon opens a contextual menu with the options described on the next table.
Available options on property's contextual menu
Option
Description
Reset
Returns the value of the selected property to its default value, if it was modified by the user
Copy
Copies the value of the selected property to the Clipboard
Paste
Pastes the Clipboard value to the value of the selected property
Edit
Allows editing the value of the selected property
NOTE
The options on a property's contextual menu may be enabled or disabled, depending on property's data type.
