OPC Server's Tags and Settings |
1.In Elipse SCADA's Organizer, select the OPCServers item and click the desired OPC Driver.
2.Click Export.
Exporting OPC Server's settings and Tags
3.Select a file's location and name to generate. In addition to this file with OPC Tag settings, a new file is generated with the same name, followed by an _Alarms suffix. This file is used later when importing alarm configurations to Elipse E3.
To import these OPC Tags to Elipse E3, follow these procedures:
1.In Organizer, insert a new OPC Driver.
2.Rename this OPC Driver to the same OPC Driver's name used in Elipse SCADA application, so that all OPC Driver's Tag references are correctly imported later.
3.Right-click this OPC Driver and select the Import option.
4.On the list of file types, select the Elipse SCADA files (*.e2f) option, and then select the file previously exported, without the _Alarms suffix. There is no need to select a template.
