Logs and Failure Report |
During the import or export process, a log file with errors and other relevant events that occurred during the process is generated, in case the ImportExport log section is enabled. To enable this section, please check chapter Advanced Settings.
By the end of the operation, there is an option to view an import failure report. In this report, there is a list of failures which are probably CSV file errors, such as an object not found.
Import failure report
