Acess via Link
Acess via Link
To access AppBrowser from a Link, open the Properties Window, select the Links tab, the desired property, and then click Properties on the right. AppBrowser is then opened and objects are displayed according to the next figure.
AppBrowser via Links
In this case, only object properties are displayed on window's center panel. Their methods are not displayed, because they are not allowed in Links.
