Non-Decimal-Base Format
Formats for non-decimal bases always present the whole part of the formatted numerical value, and they are also not sensitive to signs. As in decimal bases, if the number contains more digits than required in this format, these digits are presented anyway.
Currently, these formats are limited to 32-bit numbers. In case the value's integer part exceeds this limit, this format returns an error. The next table contains examples of values formatted using a non-decimal-base format.
Non-decimal-base formats
Data
Format
Formatted Output
255
"0x"XXX
0x0FF
12345
oooo\o
30071o
987
B
1111011011
12
BBBB - BBBB
0000 - 1100
